Giriş
This will show a step-by-step process in replacing the camera's mic.
Parçalar
Hiçbir parçaya gerek yok.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
  3. Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
    • Remove 7 screws.
      • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
      • 4 (4.45mm) screws on the bottom of the camera.
      • 2 (2.95mm) screws on the left side of the camera.
  4. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  5. Remove the rear camera casing. Remove the front casing.
    • Remove the rear camera casing.
    • Remove the front casing.
  6. Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
    • Remove the top panel screw (1x 4.37mm).
  7. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  8. Remove the top panel. Remove the top panel.
    • Remove the top panel.
  9. Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  10. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
    • Separate the inner casing from the tripod mount.
  11. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
    • Gently pull the orange tab out of the circuit board.
  12. Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
    • Carefully flip the LCD panel to expose the central circuit board.
  13. Remove the (1x 3.33mm) screw from the menu button panel .
    • Remove the (1x 3.33mm) screw from the menu button panel .
  14. Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
    • Pull the second orange tab from the circuit board and remove the buttons.
  15. Flip up the LCD screen to reveal the two orange ribbon cables. Disconnect the two ribbons cables from their sockets on the motherboard. Disconnect the two ribbons cables from their sockets on the motherboard.
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  16. Locate the microphone on top of the camera
    • Locate the microphone on top of the camera
  17. With a pry bar, remove microphone away from camera carefully.
    • With a pry bar, remove microphone away from camera carefully.
  18. Release it from it's pin and desolder
    • Release it from it's pin and desolder
Sonuç
Bir başkası bu kılavuzu tamamladı.
Odessa
55 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G8
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 1,816
