1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  7. Gently lift up the LCD screen after removing back casing. Find the point where the orange ribbon cable attaches to mother board.
    • Gently lift up the LCD screen after removing back casing.
    • Find the point where the orange ribbon cable attaches to mother board.
  8. Use plastic opening tool to gently lift up on the ribbon cable fastener. Note: It does not take much pressure to release fastener.
    • Use plastic opening tool to gently lift up on the ribbon cable fastener.
    • Note: It does not take much pressure to release fastener.
  9. Lift LCD Screen off of device.
    • Lift LCD Screen off of device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian
252 İtibar
2 adet Kılavuz yazıldı
Takım
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 103
