Ana içeriğe geç
Kodak EasyShare M381 Screen Replacement
Neye ihtiyacın var
    1. Kodak EasyShare M381 Screen Replacement, Battery: adım 1, 2 resimden 1. Kodak EasyShare M381 Screen Replacement, Battery: adım 1, 2 resimden 2.
      • First, press in and slide forward the battery latch as indicated by the arrow.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare M381 Screen Replacement: adım 2, 1 resimden 1.
      • Press down on battery until you hear a click and release it. Battery should easily slide out.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: adım 3, 3 resimden 1. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: adım 3, 3 resimden 2. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: adım 3, 3 resimden 3.
      • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
      • Using a magnetized surface to keep from losing screws may be very helpful.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare M381 Screen Replacement: adım 4, 2 resimden 1. Kodak EasyShare M381 Screen Replacement: adım 4, 2 resimden 2.
      • Using both hands, carefully pull the frame apart from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare M381 Screen Replacement, Screen: adım 5, 1 resimden 1.
      • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare M381 Screen Replacement: adım 6, 1 resimden 1.
      • Remove dial button located on top of camera, by gently pulling up.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak EasyShare M381 Screen Replacement: adım 7, 2 resimden 1. Kodak EasyShare M381 Screen Replacement: adım 7, 2 resimden 2.
      • Starting at one side, carefully work the chrome frame off of the camera itself.
      • Be careful not to disturb the shutter or flash buttons on top of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak EasyShare M381 Screen Replacement: adım 8, 1 resimden 1.
      • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
      FixBot'a Sor
      Yorum Ekle
    5. Kodak EasyShare M381 Screen Replacement: adım 9, 3 resimden 1. Kodak EasyShare M381 Screen Replacement: adım 9, 3 resimden 2. Kodak EasyShare M381 Screen Replacement: adım 9, 3 resimden 3.
      • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
      • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
      • Slide panel away from camera.
      FixBot'a Sor
      Yorum Ekle
    6. Kodak EasyShare M381 Screen Replacement: adım 10, 2 resimden 1. Kodak EasyShare M381 Screen Replacement: adım 10, 2 resimden 2.
      • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
      • Screen should now be detached. Gently lift it away from the base of the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 902
