Ana içeriğe geç
Kodak EasyShare M530 Control Buttons Replacement
Neye ihtiyacın var
  1. Kodak EasyShare M530 Control Buttons Replacement, Control Buttons: adım 1, 2 resimden 1. Kodak EasyShare M530 Control Buttons Replacement, Control Buttons: adım 1, 2 resimden 2.
    • Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
  2. Kodak EasyShare M530 Control Buttons Replacement: adım 2, 2 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 2, 2 resimden 2.
    • Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
  3. Kodak EasyShare M530 Control Buttons Replacement: adım 3, 3 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 3, 3 resimden 2. Kodak EasyShare M530 Control Buttons Replacement: adım 3, 3 resimden 3.
    • To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
  4. Kodak EasyShare M530 Control Buttons Replacement: adım 4, 3 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 4, 3 resimden 2. Kodak EasyShare M530 Control Buttons Replacement: adım 4, 3 resimden 3.
    • Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
  5. Kodak EasyShare M530 Control Buttons Replacement: adım 5, 2 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 5, 2 resimden 2.
    • Remove additional screws near lens.
  6. Kodak EasyShare M530 Control Buttons Replacement: adım 6, 2 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 6, 2 resimden 2.
    • This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
  7. Kodak EasyShare M530 Control Buttons Replacement: adım 7, 2 resimden 1. Kodak EasyShare M530 Control Buttons Replacement: adım 7, 2 resimden 2.
    • Remove buttons from back case of screen cover. Replace with new set of buttons.
  8. Kodak EasyShare M530 Control Buttons Replacement: adım 8, 1 resimden 1.
    • Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
Sonuç
Once you purchase these parts, follow the given instructions. To reassemble your device, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Elizabeth
291 İtibar
2 adet Kılavuz yazıldı
Ekip
Penn State, Team 1-2, Kaschak Winter 2015 Penn State, Team 1-2, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S1G2
1 Üye
4 adet Kılavuz yazıldı
1Rehber Yorum
como cambio la tapa de la bateria y pin de carga
Dario - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 786
