Ana içeriğe geç
Kodak EasyShare V570 Battery Replacement
  1. Kodak EasyShare V570 Battery Replacement, Battery: adım 1, 3 resimden 1. Kodak EasyShare V570 Battery Replacement, Battery: adım 1, 3 resimden 2. Kodak EasyShare V570 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off your camera before beginning the replacement.
    • Take a finger or two and slide back the compartment where the battery will be and lift it up.
  2. Kodak EasyShare V570 Battery Replacement: adım 2, 2 resimden 1. Kodak EasyShare V570 Battery Replacement: adım 2, 2 resimden 2.
    • Be careful when pulling back the brown tap it can be a little tricky.
    • Push back the brown tab with your finger.
  3. Kodak EasyShare V570 Battery Replacement: adım 3, 3 resimden 1. Kodak EasyShare V570 Battery Replacement: adım 3, 3 resimden 2. Kodak EasyShare V570 Battery Replacement: adım 3, 3 resimden 3.
    • Take out the old battery from its compartment with 2 fingers
    • If it doesn't come out that way turn the camera towards you and let it slide out onto your hand.
  4. Kodak EasyShare V570 Battery Replacement: adım 4, 2 resimden 1. Kodak EasyShare V570 Battery Replacement: adım 4, 2 resimden 2.
    • Insert the new battery by pulling down the brown mark.
    • Grab the new battery and insert it into the battery compartment
    • Please do not use force while inserting the new battery.
    • Make sure that the battery has its corner facing down and inwards at the camera.
  5. Kodak EasyShare V570 Battery Replacement: adım 5, 3 resimden 1. Kodak EasyShare V570 Battery Replacement: adım 5, 3 resimden 2. Kodak EasyShare V570 Battery Replacement: adım 5, 3 resimden 3.
    • Be careful to not use too much force.
    • Lightly push the cover down and slide it inward.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 162
