Ana içeriğe geç
Kodak EasyShare V570 Case Replacement
Neye ihtiyacın var
  1. Kodak EasyShare V570 Case Replacement, Case: adım 1, 2 resimden 1. Kodak EasyShare V570 Case Replacement, Case: adım 1, 2 resimden 2.
    • Here is the front, back, and right side of the camera.
  2. Kodak EasyShare V570 Case Replacement: adım 2, 3 resimden 1. Kodak EasyShare V570 Case Replacement: adım 2, 3 resimden 2. Kodak EasyShare V570 Case Replacement: adım 2, 3 resimden 3.
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
  3. Kodak EasyShare V570 Case Replacement: adım 3, 3 resimden 1. Kodak EasyShare V570 Case Replacement: adım 3, 3 resimden 2. Kodak EasyShare V570 Case Replacement: adım 3, 3 resimden 3.
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
  4. Kodak EasyShare V570 Case Replacement: adım 4, 2 resimden 1. Kodak EasyShare V570 Case Replacement: adım 4, 2 resimden 2.
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 146
