Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Next, press down on the red lever which holds the battery in place.
    • Next, press down on the red lever which holds the battery in place.
  3. Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
Sonuç
Jack
190 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G16
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,774
