Ana içeriğe geç
Kodak Easyshare C813 Battery Door Replacement
Neye ihtiyacın var
  1. Kodak Easyshare C813 Battery Door Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Battery Door Replacement: adım 2, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 2, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 2, 3 resimden 3.
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Battery Door Replacement, Back Cover: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
  4. Kodak Easyshare C813 Battery Door Replacement: adım 4, 1 resimden 1.
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Battery Door Replacement: adım 5, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 5, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 5, 3 resimden 3.
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Battery Door Replacement: adım 6, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 6, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 6, 3 resimden 3.
    Phillips #00 Screwdriver
    $5.49
    Satın Al
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Battery Door Replacement: adım 7, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 7, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 7, 3 resimden 3.
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Battery Door Replacement: adım 8, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 8, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 8, 3 resimden 3.
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Battery Door Replacement, Front Cover: adım 9, 2 resimden 1. Kodak Easyshare C813 Battery Door Replacement, Front Cover: adım 9, 2 resimden 2.
    • Open the battery door.
  10. Kodak Easyshare C813 Battery Door Replacement: adım 10, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 10, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 10, 3 resimden 3.
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Battery Door Replacement: adım 11, 1 resimden 1.
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Battery Door Replacement, Battery Door: adım 12, 2 resimden 1. Kodak Easyshare C813 Battery Door Replacement, Battery Door: adım 12, 2 resimden 2.
    • Open the battery door by pulling in direction of arrow
  13. Kodak Easyshare C813 Battery Door Replacement: adım 13, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 13, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 13, 3 resimden 3.
    Heavy-Duty Spudger
    Satın Al
  14. Kodak Easyshare C813 Battery Door Replacement: adım 14, 3 resimden 1. Kodak Easyshare C813 Battery Door Replacement: adım 14, 3 resimden 2. Kodak Easyshare C813 Battery Door Replacement: adım 14, 3 resimden 3.
    • The spring is small and easy to lose
    • Carefully remove battery door and spring
    • Make spring is in correct orientation when putting back
    • The spring should hook onto a small hole in the door
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Susan Marano
336 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G22
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 43
Her zaman: 12,046
