Giriş
This guide will show you Step-By-Step on how to fix a paper jam on your Kodak EasyShare Printer Dock (Series 3)
Neye ihtiyacın var
Identify that your printer is jammed. This is usually indicated by the paper light blinking quickly.
Gently pull the paper tray out of the printing dock to remove it.
When the paper tray is empty, the paper light should glow a steady amber.
Disconnect the power adapter from the printer for 10 seconds, and then reconnect the cord.
Wait for the printer to initialize in order for the jammed paper to exit from the back side.
Notice: Carefully remove the paper if it does not automatically eject.
With the paper tray in hand, open the front lid in order to gain access to the paper supply.
Take hold of the paper bundle, and carefully “fan” it to keep the sheets from sticking together.
Reload the paper tray by sliding the paper bundle back into the intended slot, and then close the lid.
Next, slide the paper tray in the printer tray slot until the tray locks into place.
Press the power or print button to clear the paper error and resume printing.
