Ana içeriğe geç
Kodak Easyshare V1003 LCD Display Replacement
Neye ihtiyacın var
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: adım 2, 1 resimden 1.
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: adım 3, 1 resimden 1.
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: adım 4, 1 resimden 1.
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: adım 5, 2 resimden 1. Kodak Easyshare V1003  LCD Display Replacement: adım 5, 2 resimden 2.
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: adım 6, 3 resimden 1. Kodak Easyshare V1003  LCD Display Replacement, Buttons: adım 6, 3 resimden 2. Kodak Easyshare V1003  LCD Display Replacement, Buttons: adım 6, 3 resimden 3.
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: adım 7, 3 resimden 1. Kodak Easyshare V1003  LCD Display Replacement: adım 7, 3 resimden 2. Kodak Easyshare V1003  LCD Display Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: adım 8, 3 resimden 1. Kodak Easyshare V1003  LCD Display Replacement: adım 8, 3 resimden 2. Kodak Easyshare V1003  LCD Display Replacement: adım 8, 3 resimden 3.
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: adım 9, 1 resimden 1.
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: adım 10, 1 resimden 1.
    • Take apart the LCD display from the back case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Vanessa Soares
246 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G4, Martin Spring 2017 UMass Dartmouth, Team S9-G4, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G4
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 952
