Ana içeriğe geç
Kodak Easyshare V1003 Lens Replacement
Neye ihtiyacın var
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: adım 2, 1 resimden 1.
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: adım 3, 1 resimden 1.
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: adım 4, 1 resimden 1.
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: adım 5, 2 resimden 1. Kodak Easyshare V1003 Lens  Replacement: adım 5, 2 resimden 2.
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: adım 6, 2 resimden 1. Kodak Easyshare V1003 Lens  Replacement, Lens: adım 6, 2 resimden 2.
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: adım 7, 1 resimden 1.
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: adım 8, 2 resimden 1. Kodak Easyshare V1003 Lens  Replacement: adım 8, 2 resimden 2.
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: adım 9, 2 resimden 1. Kodak Easyshare V1003 Lens  Replacement: adım 9, 2 resimden 2.
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: adım 10, 1 resimden 1.
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: adım 11, 2 resimden 1. Kodak Easyshare V1003 Lens  Replacement: adım 11, 2 resimden 2.
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: adım 12, 3 resimden 1. Kodak Easyshare V1003 Lens  Replacement: adım 12, 3 resimden 2. Kodak Easyshare V1003 Lens  Replacement: adım 12, 3 resimden 3.
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
Sonuç
Sarah Berry
313 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G4, Martin Spring 2017 UMass Dartmouth, Team S9-G4, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 13
Son 30 gün: 22
Her zaman: 416
