Ana içeriğe geç
Kodak Easyshare Z981 Back Cover Replacement
Neye ihtiyacın var
  1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
  2. Kodak Easyshare Z981 Back Cover Replacement: adım 2, 1 resimden 1.
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
  3. Kodak Easyshare Z981 Back Cover Replacement: adım 3, 2 resimden 1. Kodak Easyshare Z981 Back Cover Replacement: adım 3, 2 resimden 2.
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Back Cover Replacement: adım 4, 2 resimden 1. Kodak Easyshare Z981 Back Cover Replacement: adım 4, 2 resimden 2.
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Olivia Boyna
509 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 719
