Ana içeriğe geç
Kodak Easyshare Z981 Flash Button Replacement
Neye ihtiyacın var
  1. Kodak Easyshare Z981 Flash Button Replacement, Flash Button: adım 1, 2 resimden 1. Kodak Easyshare Z981 Flash Button Replacement, Flash Button: adım 1, 2 resimden 2.
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Flash Button Replacement: adım 2, 3 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 2, 3 resimden 2. Kodak Easyshare Z981 Flash Button Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) on the inside of the battery cover
    • Four (4) 6mm screws on the sides of the camera (two on each side)
  3. Kodak Easyshare Z981 Flash Button Replacement: adım 3, 1 resimden 1.
    • Start from a corner and gently remove the bottom of the camera.
    • The cover will easily lift off, so not much pressure is required.
  4. Kodak Easyshare Z981 Flash Button Replacement: adım 4, 2 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 4, 2 resimden 2.
    • Use a Plastic Opening Tool to remove the back of the camera
  5. Kodak Easyshare Z981 Flash Button Replacement: adım 5, 3 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 5, 3 resimden 2. Kodak Easyshare Z981 Flash Button Replacement: adım 5, 3 resimden 3.
    • Remove the four (4) 3mm screws attaching the LCD screen to the circuit board.
    • Use Tweezers to carefully detach the ribbon cable
    • Use extreme caution on this step, as the ribbon cable is very fragile and can rip very easily.
  6. Kodak Easyshare Z981 Flash Button Replacement: adım 6, 3 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 6, 3 resimden 2. Kodak Easyshare Z981 Flash Button Replacement: adım 6, 3 resimden 3.
    • Open the flash compartment and remove two (2) 3mm screws.
  7. Kodak Easyshare Z981 Flash Button Replacement: adım 7, 2 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 7, 2 resimden 2.
    • Use a Plastic Opening Tool to carefully remove the top of the camera.
    • Use caution when removing the top of the camera
  8. Kodak Easyshare Z981 Flash Button Replacement: adım 8, 3 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 8, 3 resimden 2. Kodak Easyshare Z981 Flash Button Replacement: adım 8, 3 resimden 3.
    • Remove four (4) 3mm screws from the circuit board underneath the button set.
    • Gently move the circuit board aside.
    • Gently move aside the metal sheet.
  9. Kodak Easyshare Z981 Flash Button Replacement: adım 9, 2 resimden 1. Kodak Easyshare Z981 Flash Button Replacement: adım 9, 2 resimden 2.
    • Use Tweezers to carefully remove the flash button.
    • The button should simply pop out when light pressure is applied.
Sonuç
Olivia Boyna
509 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 771
