Ana içeriğe geç
Kodak Easyshare Z981 LCD Screen Replacement
Neye ihtiyacın var
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Open the battery cover and remove batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 LCD Screen Replacement: adım 2, 2 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
  4. Kodak Easyshare Z981 LCD Screen Replacement: adım 4, 2 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement: adım 4, 2 resimden 2.
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  5. Kodak Easyshare Z981 LCD Screen Replacement: adım 5, 2 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  6. Kodak Easyshare Z981 LCD Screen Replacement: adım 6, 2 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
  7. Kodak Easyshare Z981 LCD Screen Replacement: adım 7, 3 resimden 1. Kodak Easyshare Z981 LCD Screen Replacement: adım 7, 3 resimden 2. Kodak Easyshare Z981 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Gently lift up the metal brace and use a pair if tweezers to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Ramirez
152 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 821
