Ana içeriğe geç
Kodak Easyshare Z981 Top Shutter Button Replacement
Neye ihtiyacın var
  1. Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: adım 1, 2 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: adım 1, 2 resimden 2.
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 2, 2 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Remove all screws on the outside of the camera with a 00 Phillips-Head screwdriver
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) screws on the bottom of the camera
    • Four (4) screws inside the battery cover
  3. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 3, 3 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 3, 3 resimden 2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 3, 3 resimden 3.
    • Detach the bottom part of the camera by removing four (4) 3mm screws
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 4, 2 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 4, 2 resimden 2.
    • Use the Plastic Opening Tool to put light pressure and remove the back cover of the camera
    • Be gentle when removing the back cover
  5. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 5, 3 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 5, 3 resimden 2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 5, 3 resimden 3.
    • Unscrew the four (4) 3mm screws to remove the screen from the circuit board
    • Use Tweezers to delicately detach the ribbon cable
    • Carefully remove the screen brace from the circuit board
  6. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 6, 3 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 6, 3 resimden 2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 6, 3 resimden 3.
    • Remove the two (2) 3mm screws from inside flash compartment
    • Remove one (1) 3mm screw from the circuit board
  7. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 7, 2 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 7, 2 resimden 2.
    • Use the Tweezers to detach the ribbon cable connecter from the circuit board
    • Use the Plastic Opening Tool to gently apply pressure on the top of the camera and remove the upper portion
  8. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 8, 3 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 8, 3 resimden 2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 8, 3 resimden 3.
    • Remove the four (4) 3mm screws from the circuit board directly underneath the shutter button and gently move the circuit board aside
    • Lift up the metal clamp
    • Use caution when removing the circuit board to avoid tearing the wires connected
  9. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 9, 3 resimden 1. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 9, 3 resimden 2. Kodak Easyshare Z981 Top Shutter Button Replacement: adım 9, 3 resimden 3.
    • Pull the small brace on top of the shutter button
    • Using the Tweezers, gently remove the shutter button
Sonuç
Matthew Myers
219 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
looking for z981 bottom wrist grip jwkcm1978@hotmail.com
jwkcm1978 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 690
