Ana içeriğe geç
Kodak PixPro AZ251 Back Cover Replacement
Neye ihtiyacın var
    1. Kodak PixPro AZ251 Back Cover Replacement, Batteries: adım 1, 2 resimden 1. Kodak PixPro AZ251 Back Cover Replacement, Batteries: adım 1, 2 resimden 2.
      • Slide switch to open lock position.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak PixPro AZ251 Back Cover Replacement: adım 2, 2 resimden 1. Kodak PixPro AZ251 Back Cover Replacement: adım 2, 2 resimden 2.
      • Press down on the battery cover and slide outwards to open.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak PixPro AZ251 Back Cover Replacement: adım 3, 1 resimden 1.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak PixPro AZ251 Back Cover Replacement, Back Cover: adım 4, 3 resimden 1. Kodak PixPro AZ251 Back Cover Replacement, Back Cover: adım 4, 3 resimden 2. Kodak PixPro AZ251 Back Cover Replacement, Back Cover: adım 4, 3 resimden 3.
      • Remove a total of four 5mm JIS #000 screws from around the camera:
      • Two screws from the right side.
      • Two screws from the left side.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak PixPro AZ251 Back Cover Replacement: adım 5, 1 resimden 1.
      • Remove the single 5mm Phillips #00 screw from the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak PixPro AZ251 Back Cover Replacement: adım 6, 2 resimden 1. Kodak PixPro AZ251 Back Cover Replacement: adım 6, 2 resimden 2.
      • Open the flash module.
      • Remove the two 6mm JIS #00 screws found inside of the flash housing.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak PixPro AZ251 Back Cover Replacement: adım 7, 3 resimden 1. Kodak PixPro AZ251 Back Cover Replacement: adım 7, 3 resimden 2. Kodak PixPro AZ251 Back Cover Replacement: adım 7, 3 resimden 3.
      • Use a plastic opening tool to pry apart both halves of the camera.
      • Remove the back panel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luiza Oliveira
298 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Cagle Spring 2018 USF Tampa, Team S1-G1, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 1,191
