Ana içeriğe geç
Kodak PixPro AZ251 Mode Dial Replacement
Neye ihtiyacın var
  1. Kodak PixPro AZ251 Mode Dial Replacement, Batteries: adım 1, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement, Batteries: adım 1, 2 resimden 2.
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Mode Dial Replacement: adım 2, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 2, 2 resimden 2.
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Mode Dial Replacement: adım 3, 1 resimden 1.
    • Remove the batteries.
  4. Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: adım 4, 3 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: adım 4, 3 resimden 2. Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: adım 4, 3 resimden 3.
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 Mode Dial Replacement: adım 5, 1 resimden 1.
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 Mode Dial Replacement: adım 6, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 6, 2 resimden 2.
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 Mode Dial Replacement: adım 7, 3 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 7, 3 resimden 2. Kodak PixPro AZ251 Mode Dial Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 Mode Dial Replacement, LCD Screen: adım 8, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement, LCD Screen: adım 8, 2 resimden 2.
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 Mode Dial Replacement: adım 9, 1 resimden 1.
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 Mode Dial Replacement: adım 10, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 10, 2 resimden 2.
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 Mode Dial Replacement: adım 11, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 11, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
  12. Kodak PixPro AZ251 Mode Dial Replacement, Mode Dial: adım 12, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement, Mode Dial: adım 12, 2 resimden 2.
    • Remove one 4-mm screw using a J000 screwdriver from the top of the camera, near the mode dial.
  13. Kodak PixPro AZ251 Mode Dial Replacement: adım 13, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 13, 2 resimden 2.
    • Using the tweezers, disconnect the orange cable connection at the top of the motherboard near the mode dial.
  14. Kodak PixPro AZ251 Mode Dial Replacement: adım 14, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 14, 2 resimden 2.
    • Pull the top side cover up.
    • Rotate the top side cover to the right.
    • Rotate carefully to avoid breaking the screw attaching the top side cover to the main body of the camera.
  15. Kodak PixPro AZ251 Mode Dial Replacement: adım 15, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 15, 2 resimden 2.
    • Turn the camera upside down.
    • Remove two 2mm JIS #000 screws from the metal base of the mode dial.
  16. Kodak PixPro AZ251 Mode Dial Replacement: adım 16, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 16, 2 resimden 2.
    • Lift the metal base and remove the 4mm JIS #000 screw from the center of the mode dial.
  17. Kodak PixPro AZ251 Mode Dial Replacement: adım 17, 2 resimden 1. Kodak PixPro AZ251 Mode Dial Replacement: adım 17, 2 resimden 2.
    • The mode dial should now be loose and can be easily removed from the top side cover.
    • Turn the mode dial upside down to remove the metal part inside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel Llewellyn
509 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Cagle Spring 2018 USF Tampa, Team S1-G1, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 576
