Ana içeriğe geç
Kodak PixPro AZ251 Motherboard Replacement
Neye ihtiyacın var
  1. Kodak PixPro AZ251 Motherboard Replacement, Batteries: adım 1, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement, Batteries: adım 1, 2 resimden 2.
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Motherboard Replacement: adım 2, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 2, 2 resimden 2.
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the batteries.
  4. Kodak PixPro AZ251 Motherboard Replacement, Back Cover: adım 4, 3 resimden 1. Kodak PixPro AZ251 Motherboard Replacement, Back Cover: adım 4, 3 resimden 2. Kodak PixPro AZ251 Motherboard Replacement, Back Cover: adım 4, 3 resimden 3.
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 Motherboard Replacement: adım 6, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 6, 2 resimden 2.
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 Motherboard Replacement: adım 7, 3 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 7, 3 resimden 2. Kodak PixPro AZ251 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: adım 8, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: adım 8, 2 resimden 2.
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 Motherboard Replacement: adım 10, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 10, 2 resimden 2.
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 Motherboard Replacement: adım 11, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 11, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
  12. Kodak PixPro AZ251 Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Remove three 4mm JIS #000 screws from the metal housing plate.
  13. Kodak PixPro AZ251 Motherboard Replacement: adım 13, 1 resimden 1.
    • Lift the metal housing plate out using your hands.
  14. Kodak PixPro AZ251 Motherboard Replacement: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the orange cable, connecting the small metal switch plate to the motherboard, by pulling it outwards with tweezers.
  15. Kodak PixPro AZ251 Motherboard Replacement: adım 15, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 15, 2 resimden 2.
    • Disconnect two orange cables, one at the top and the other at the bottom of the motherboard, by pulling them outwards with tweezers.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  16. Kodak PixPro AZ251 Motherboard Replacement: adım 16, 2 resimden 1. Kodak PixPro AZ251 Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the rectangular black cushion pad on the bottom left of the motherboard by pulling it upwards with your hands.
    • Disconnect the orange cable by pulling it outwards with tweezers.
  17. Kodak PixPro AZ251 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the two 4mm JIS #000 screws from the motherboard.
  18. Kodak PixPro AZ251 Motherboard Replacement: adım 18, 1 resimden 1.
    • Desolder two pairs of electrical cable connections on the top left of the motherboard using the soldering iron.
    • Desolder the metal connector joining the two parts of the motherboard using the soldering iron.
    • The unsoldering steps are not shown.
  19. Kodak PixPro AZ251 Motherboard Replacement: adım 19, 1 resimden 1.
    • Lift the motherboard up using your hands.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Deborah Oliveira
319 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Cagle Spring 2018 USF Tampa, Team S1-G1, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,662
