Ana içeriğe geç
Kodak PixPro AZ251 Rubber Grip Replacement
Neye ihtiyacın var
  1. Kodak PixPro AZ251 Rubber Grip Replacement, Batteries: adım 1, 2 resimden 1. Kodak PixPro AZ251 Rubber Grip Replacement, Batteries: adım 1, 2 resimden 2.
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Rubber Grip Replacement: adım 2, 2 resimden 1. Kodak PixPro AZ251 Rubber Grip Replacement: adım 2, 2 resimden 2.
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Rubber Grip Replacement: adım 3, 1 resimden 1.
    • Remove the batteries.
  4. Kodak PixPro AZ251 Rubber Grip Replacement, Rubber Grip: adım 4, 1 resimden 1.
    • Insert the plastic opening tool underneath the rubber on the bottom corner.
  5. Kodak PixPro AZ251 Rubber Grip Replacement: adım 5, 3 resimden 1. Kodak PixPro AZ251 Rubber Grip Replacement: adım 5, 3 resimden 2. Kodak PixPro AZ251 Rubber Grip Replacement: adım 5, 3 resimden 3.
    • Slide the plastic opening tool along the perimeter of the rubber grip to unbind the glue.
  6. Kodak PixPro AZ251 Rubber Grip Replacement: adım 6, 3 resimden 1. Kodak PixPro AZ251 Rubber Grip Replacement: adım 6, 3 resimden 2. Kodak PixPro AZ251 Rubber Grip Replacement: adım 6, 3 resimden 3.
    • Pry upwards until you can grip the rubber enough to pull off.
Sonuç
Luiza Oliveira
298 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Cagle Spring 2018 USF Tampa, Team S1-G1, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 357
