Ana içeriğe geç
Kodak S100 EF Back Cover Replacement
Neye ihtiyacın var
  1. Kodak S100 EF Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Kodak S100 EF Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Back Cover Replacement: adım 2, 1 resimden 1.
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Back Cover Replacement: adım 3, 1 resimden 1.
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
Sonuç
Michelle
107 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 1,637
