Ana içeriğe geç
Kodak S100 EF Film Replacement
Neye ihtiyacın var
  1. Kodak S100 EF Film Replacement, Film: adım 1, 1 resimden 1.
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. Kodak S100 EF Film Replacement: adım 2, 1 resimden 1.
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kodak S100 EF Film Replacement: adım 3, 1 resimden 1.
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • Remove the old roll of film and slide in the new roll.
    • Push the roller back down to secure the film.
  4. Kodak S100 EF Film Replacement: adım 4, 1 resimden 1.
    • To prepare the film for use, slightly pull the tail of the film out of the roll.
    • Drag the tail end of the film past the rotating column on the right side.
    • Attach the hooks at the base of the column to the holes located at the bottom of the film.
  5. Kodak S100 EF Film Replacement: adım 5, 1 resimden 1.
    • After the film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
Sonuç
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Bir başkası bu kılavuzu tamamladı.
Michelle
107 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 41
Her zaman: 9,052
