Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will walk you through the process of replacing the back cover of the Kodak Signet 35.
  1. While the lens is facing away from you, there is a button at the center of the latch on the right side. Press this button with your finger and slide the latch downward. This will disengage the latch, opening the back of the camera. While the lens is facing away from you, there is a button at the center of the latch on the right side. Press this button with your finger and slide the latch downward. This will disengage the latch, opening the back of the camera. While the lens is facing away from you, there is a button at the center of the latch on the right side. Press this button with your finger and slide the latch downward. This will disengage the latch, opening the back of the camera.
    • While the lens is facing away from you, there is a button at the center of the latch on the right side. Press this button with your finger and slide the latch downward. This will disengage the latch, opening the back of the camera.
  2. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  3. Open the back cover and it will unhitch on the left.
    • Open the back cover and it will unhitch on the left.
Sonuç
Christopher Negron
113 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team 6-3, Remmell Fall 2016 USF Tampa, Team 6-3, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 213
