Ana içeriğe geç
Kodak Signet 35 Shutter Spring Replacement
Neye ihtiyacın var
    1. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: adım 1, 3 resimden 1. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: adım 1, 3 resimden 2. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: adım 1, 3 resimden 3.
      • While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak Signet 35 Shutter Spring Replacement: adım 2, 2 resimden 1. Kodak Signet 35 Shutter Spring Replacement: adım 2, 2 resimden 2.
      • Remove the lever from the stopper by pushing it back and then upwards.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak Signet 35 Shutter Spring Replacement: adım 3, 2 resimden 1. Kodak Signet 35 Shutter Spring Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the stopper by lifting it upwards with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak Signet 35 Shutter Spring Replacement: adım 4, 3 resimden 1. Kodak Signet 35 Shutter Spring Replacement: adım 4, 3 resimden 2. Kodak Signet 35 Shutter Spring Replacement: adım 4, 3 resimden 3.
      • Using tweezers, unhitch the spring from the base and remove it by lifting upwards.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Mellyssa Greene
134 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 6-3, Remmell Fall 2016 USF Tampa, Team 6-3, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G3
4 Üyeler
9 adet Kılavuz yazıldı
2Kılavuz Yorumları
What kind of spring can be used to replace it or how would one revitalize the old spring?
Ben Le - Yanıt Paylaş
What does “front lens assembly” look like? what parts do I have to unscrew?
Shawn Reynolds - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 60
Her zaman: 3,473
