Ana içeriğe geç
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Neye ihtiyacın var
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: adım 1, 2 resimden 1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: adım 1, 2 resimden 2.
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: adım 2, 1 resimden 1.
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: adım 3, 1 resimden 1.
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: adım 4, 1 resimden 1.
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Sonuç
Christopher Peterson
330 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-1, Forte Fall 2015 Cal Poly, Team 11-1, Forte Fall 2015 üyesi
CPSU-FORTE-F15S11G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,271
