Ana içeriğe geç
Kolcraft Cloud Plus Wheel Replacement
Neye ihtiyacın var
  1. Kolcraft Cloud Plus Wheel Replacement, Wheel: adım 1, 2 resimden 1. Kolcraft Cloud Plus Wheel Replacement, Wheel: adım 1, 2 resimden 2.
    • Applying too much force to the spudger can cause the spudger to bend or the hubcap to break. To avoid this, try prying the hubcap from a different angle or positioning your spudger at a different points around the hubcap.
    • Use the spaded side of the metal spudger to pry off the small black hubcap on the outside of the rear wheel.
  2. Kolcraft Cloud Plus Wheel Replacement: adım 2, 2 resimden 1. Kolcraft Cloud Plus Wheel Replacement: adım 2, 2 resimden 2.
    • Pull on the looped end of the cotter pin to remove it.
  3. Kolcraft Cloud Plus Wheel Replacement: adım 3, 2 resimden 1. Kolcraft Cloud Plus Wheel Replacement: adım 3, 2 resimden 2.
    • Remove the metal washer by sliding it off the axle.
  4. Kolcraft Cloud Plus Wheel Replacement: adım 4, 1 resimden 1.
    • Slide the wheel off of the axle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Peterson
330 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-1, Forte Fall 2015 Cal Poly, Team 11-1, Forte Fall 2015 üyesi
CPSU-FORTE-F15S11G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 4,282
