Ana içeriğe geç
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: adım 1, 2 resimden 1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: adım 1, 2 resimden 2.
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: adım 2, 1 resimden 1.
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Sonuç
Hieu Ngo
431 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 1,196
