Ana içeriğe geç
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: adım 1, 2 resimden 1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: adım 1, 2 resimden 2.
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: adım 2, 1 resimden 1.
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
    Is it correct “insert” the batteries?
    It is not advisable to take them out !
    Any how, I was able to reach the cursor left button, on a Dimage Z5, that is not working. It looks like the problem is on the mechanicall button and not on the switch itself.
    There are small differences, between Z3 and Z5, concerning disassembling, mainly a screw, longer than the others, close to the USB port.
    So, thanks a lot for the help you gave to me.
    Júio
    Joaquim - Yanıt
Sonuç
Hieu Ngo
431 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G4
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 1,204
