Ana içeriğe geç
Konica Minolta DiMAGE Z3 LCD Screen Replacement
Neye ihtiyacın var
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: adım 1, 2 resimden 1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: adım 1, 2 resimden 2.
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: adım 2, 1 resimden 1.
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: adım 3, 2 resimden 1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: adım 3, 2 resimden 2.
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: adım 4, 1 resimden 1.
    • Remove the 2 small screws under the viewfinder.
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: adım 5, 1 resimden 1.
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: adım 6, 1 resimden 1.
    • Remove 6 screws on the bottom panel.
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: adım 7, 1 resimden 1.
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Remove 1 screw inside the battery chamber.
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: adım 10, 1 resimden 1.
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
Sonuç
Hieu Ngo
431 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 792
