Ana içeriğe geç
Koosh Vortex Tornado Loading Spring Replacement
Neye ihtiyacın var
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: adım 1, 1 resimden 1.
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
    FixBot'a Sor
    Yorum Ekle
  2. Koosh Vortex Tornado Loading Spring Replacement: adım 2, 1 resimden 1.
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
    FixBot'a Sor
    Yorum Ekle
  3. Koosh Vortex Tornado Loading Spring Replacement: adım 3, 1 resimden 1.
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
    FixBot'a Sor
    Yorum Ekle
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: adım 4, 1 resimden 1.
    • Slide the barrel shield and shield slide off of the gun and set aside.
    FixBot'a Sor
    Yorum Ekle
  5. Koosh Vortex Tornado Loading Spring Replacement: adım 5, 1 resimden 1.
    • Slide the rubber ring off of the barrel and set it aside.
    FixBot'a Sor
    Yorum Ekle
  6. Koosh Vortex Tornado Loading Spring Replacement: adım 6, 1 resimden 1.
    • Lift the yellow trigger from its pin and set aside.
    FixBot'a Sor
    Yorum Ekle
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: adım 7, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
    FixBot'a Sor
    Yorum Ekle
  8. Koosh Vortex Tornado Loading Spring Replacement: adım 8, 1 resimden 1.
    • Lift the yellow lever bar out of place and set aside.
    FixBot'a Sor
    Yorum Ekle
  9. Koosh Vortex Tornado Loading Spring Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Koosh Vortex Tornado Loading Spring Replacement: adım 10, 1 resimden 1.
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
    FixBot'a Sor
    Yorum Ekle
  11. Koosh Vortex Tornado Loading Spring Replacement: adım 11, 2 resimden 1. Koosh Vortex Tornado Loading Spring Replacement: adım 11, 2 resimden 2.
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lingbin Meng
204 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Harley Spring 2016 IUPUI, Team 2-4, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G4
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 69
Her zaman: 1,079
