Ana içeriğe geç
Koosh Vortex Tornado Trigger Replacement
Neye ihtiyacın var
  1. Koosh Vortex Tornado Trigger Replacement, Barrel Shield Spring: adım 1, 1 resimden 1.
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
  2. Koosh Vortex Tornado Trigger Replacement: adım 2, 1 resimden 1.
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
  3. Koosh Vortex Tornado Trigger Replacement: adım 3, 1 resimden 1.
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
  4. Koosh Vortex Tornado Trigger Replacement, Trigger: adım 4, 1 resimden 1.
    • Slide the barrel shield and shield slide off of the gun and set aside.
  5. Koosh Vortex Tornado Trigger Replacement: adım 5, 1 resimden 1.
    • Slide the rubber ring off of the barrel and set it aside.
  6. Koosh Vortex Tornado Trigger Replacement: adım 6, 1 resimden 1.
    • Lift the yellow trigger from its pin and set aside.
Sonuç
Lingbin Meng
204 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Harley Spring 2016 IUPUI, Team 2-4, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G4
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 207
