Ana içeriğe geç
Krups 963 Power Switch Replacement
Neye ihtiyacın var
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: adım 1, 1 resimden 1.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
    FixBot'a Sor
    Yorum Ekle
  2. Krups 963 Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
    FixBot'a Sor
    Yorum Ekle
  3. Krups 963 Power Switch Replacement: adım 3, 1 resimden 1.
    • Remove the bottom cover from the machine and slide it down the power cord.
    FixBot'a Sor
    Yorum Ekle
  4. Krups 963 Power Switch Replacement, Power Switch: adım 4, 1 resimden 1.
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
    FixBot'a Sor
    Yorum Ekle
  5. Krups 963 Power Switch Replacement: adım 5, 1 resimden 1.
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Wyatt Hall
866 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G25
4 Üyeler
28 adet Kılavuz yazıldı
1Rehber Yorum
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 33
Her zaman: 3,681
