Ana içeriğe geç
Krups 963 Power Switch Replacement
Neye ihtiyacın var
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: adım 1, 1 resimden 1.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: adım 3, 1 resimden 1.
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: adım 4, 1 resimden 1.
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: adım 5, 1 resimden 1.
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Sonuç
Wyatt Hall
842 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G25
4 Üyeler
Bir Yorum
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 19
Her zaman: 3,039
