Ana içeriğe geç
Krups 963 Water Heater Replacement
Neye ihtiyacın var
  1. Krups 963 Water Heater Replacement, Removing Bottom Screws: adım 1, 1 resimden 1.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Water Heater Replacement: adım 2, 1 resimden 1.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Water Heater Replacement: adım 3, 1 resimden 1.
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Water Heater Replacement, Disassembling Krups 963 Top Cover: adım 4, 1 resimden 1.
    • Remove the three 60mm Phillips size 0 screws holding the top cover on.
  5. Krups 963 Water Heater Replacement: adım 5, 1 resimden 1.
    • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
  6. Krups 963 Water Heater Replacement: adım 6, 1 resimden 1.
    • Remove the grey plastic ring from the rim of the filter basket holder.
  7. Krups 963 Water Heater Replacement: adım 7, 1 resimden 1.
    • Lift and remove the top black plastic cover from the machine.
  8. Krups 963 Water Heater Replacement, Water Heater: adım 8, 2 resimden 1. Krups 963 Water Heater Replacement, Water Heater: adım 8, 2 resimden 2.
    • Use a Phillip size 2 screw driver to remove the four 15mm screws holding the pump to the machine's base.
    • Lift the water heater up and remove it from the base.
Sonuç
Wyatt Hall
842 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G25
4 Üyeler
2 Yorum
Where do you get the new heater to replace the broken one that does not work?
Stephanie Scoby - Yanıt
The broken heating element is removed. Where do you get a new one to replace the broken one?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 3,296
