Ana içeriğe geç
Krups CafeExpress FMA110 Disassembly
Neye ihtiyacın var
  1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: adım 1, 2 resimden 1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: adım 1, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
    • Remove the metal plate.
  2. Krups CafeExpress FMA110 Disassembly: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
  3. Krups CafeExpress FMA110 Disassembly: adım 3, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 3, 2 resimden 2.
    • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
  4. Krups CafeExpress FMA110 Disassembly: adım 4, 1 resimden 1.
    • Carefully pull the silicon tubing off of the metal tube.
  5. Krups CafeExpress FMA110 Disassembly: adım 5, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 5, 2 resimden 2.
    • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
  6. Krups CafeExpress FMA110 Disassembly: adım 6, 1 resimden 1.
    • Carefully remove the silicon tubing from the upper reservoir.
  7. Krups CafeExpress FMA110 Disassembly: adım 7, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
  8. Krups CafeExpress FMA110 Disassembly: adım 8, 1 resimden 1.
    • Separate the base of the device from the upper reservoir.
  9. Krups CafeExpress FMA110 Disassembly: adım 9, 1 resimden 1.
    • Push the switch out from the inside, releasing it from the plastic base.
  10. Krups CafeExpress FMA110 Disassembly: adım 10, 1 resimden 1.
    • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
  11. Krups CafeExpress FMA110 Disassembly: adım 11, 1 resimden 1.
    • Slide the rest of the switch back through the hole in the base.
  12. Krups CafeExpress FMA110 Disassembly: adım 12, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 12, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
  13. Krups CafeExpress FMA110 Disassembly: adım 13, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 13, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
  14. Krups CafeExpress FMA110 Disassembly: adım 14, 1 resimden 1.
    • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
  15. Krups CafeExpress FMA110 Disassembly: adım 15, 1 resimden 1.
    • Disconnect the wire connectors from the thermal switch.
  16. Krups CafeExpress FMA110 Disassembly: adım 16, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
  17. Krups CafeExpress FMA110 Disassembly: adım 17, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 17, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
    • Separate the hot plate from its frame.
  18. Krups CafeExpress FMA110 Disassembly: adım 18, 2 resimden 1. Krups CafeExpress FMA110 Disassembly: adım 18, 2 resimden 2.
    • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 165
