Ana içeriğe geç
Krups F203 Coffee Grinder Base Plate Replacement
Neye ihtiyacın var
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: adım 1, 1 resimden 1.
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: adım 2, 3 resimden 1. Krups F203 Coffee Grinder Base Plate Replacement: adım 2, 3 resimden 2. Krups F203 Coffee Grinder Base Plate Replacement: adım 2, 3 resimden 3.
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: adım 3, 2 resimden 1. Krups F203 Coffee Grinder Base Plate Replacement: adım 3, 2 resimden 2.
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian Wolfskill
420 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G2
3 Üyeler
10 adet Kılavuz yazıldı
10 Yorum
Thanks! I was able to repair my broken cord.
wdswaim - Yanıt
I'mworking on it as we write .
jerry - Yanıt
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Yanıt
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Yanıt
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 53
Her zaman: 11,407
