Giriş
Sometimes, the plug or cord attached to the Krups F203 coffee grinder is defective. This guide will tell you how to replace the cord.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
The trigger button is held in with light tension clips. Gently pry them back to release.
Use the soldering iron to remove the existing solder.
Bir başkası bu kılavuzu tamamladı.
