Ana içeriğe geç
Krups F203 Coffee Grinder Trigger Assembly Replacement
Neye ihtiyacın var
  1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: adım 1, 1 resimden 1.
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 2, 3 resimden 1. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 2, 3 resimden 2. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 2, 3 resimden 3.
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 3, 2 resimden 1. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 3, 2 resimden 2.
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: adım 4, 1 resimden 1.
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 5, 2 resimden 1. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Trigger Assembly Replacement: adım 6, 1 resimden 1.
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ian Hancock
414 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G2
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 5,340
