Ana içeriğe geç
Krups quick mix bar repair slip-out shaft
Neye ihtiyacın var
  1. Krups quick mix bar repair slip-out shaft, Replacing the circlip: adım 1, 2 resimden 1. Krups quick mix bar repair slip-out shaft, Replacing the circlip: adım 1, 2 resimden 2.
    • For the knife, loosen the three small screws (size 5 in the nut box).
    • Wave from behind (back = where the quick-mix stick comes in the mixer) from the bar (here may be some strength required, do not be surprised).
    • Buy retaining ring (DIN 6799, size 4, stainless !!!)
    • Remove old circlip, attach new one. The circlip must be the last part from the end of the shaft. I've uploaded a photo of both the circlip and the inside, which can be found in the user pictures of this article.
    • Close again. I would recommend new screws, the old ones have very flat heads and are quickly turned off.
Sonuç
Finished!
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Matt
1 İtibar
1 Kılavuz yazıldı
Bir Yorum
Die Beschreibung ist sinnfrei und dient meines Erachtens dazu, Euren Pürierstab restlos zu ruinieren.
Ihr müsst das Messer fixieren und gleichzeitig hinten den Einsatz, der in den Mixer gesteckt wird gegenläufig mit einem großen Schraubenzieher, Stechbeitel o.ä. drehen. Welle lässt sich so entfernen und an der beschrieben Stelle muss der - jedenfalls auch bei mir fehlende - Sicherungsring ersetzt werden.
Chris Stoffel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,475
