Ana içeriğe geç
Kurio 10S Speakers Replacement
Neye ihtiyacın var
  1. Kurio 10S Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Speakers Replacement: adım 2, 2 resimden 1. Kurio 10S Speakers Replacement: adım 2, 2 resimden 2.
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Speakers Replacement: adım 3, 1 resimden 1.
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
    • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
  4. Kurio 10S Speakers Replacement: adım 4, 1 resimden 1.
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • Locate the two speakers on either side of the device
  6. Kurio 10S Speakers Replacement: adım 6, 2 resimden 1. Kurio 10S Speakers Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully disconnect the black and red wire from the motherboard using tweezers
    • Caution: motherboard parts are very fragile, so be careful when removing the wires
  7. Kurio 10S Speakers Replacement: adım 7, 1 resimden 1.
    • Remove the speaker from its holder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hanna Desilets
122 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015 üyesi
UMASSD-SHASTANY-S15S1G6
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
This tutorial was veryhelpful
Ralph Watson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 244
