Ana içeriğe geç
Kurio Touch 4S Battery Replacement
Neye ihtiyacın var
  1. Kurio Touch 4S Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: adım 2, 3 resimden 1. Kurio Touch 4S Battery Replacement: adım 2, 3 resimden 2. Kurio Touch 4S Battery Replacement: adım 2, 3 resimden 3.
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: adım 3, 3 resimden 1. Kurio Touch 4S Battery Replacement: adım 3, 3 resimden 2. Kurio Touch 4S Battery Replacement: adım 3, 3 resimden 3.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: adım 4, 1 resimden 1.
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: adım 6, 1 resimden 1.
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Khalid AlTamimi
275 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G5
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
do you know where to buy a replacement battery ?
Phil Bowring - Yanıt
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,598
