Ana içeriğe geç
Kurio Touch 4S Front & Rear Facing Cameras Replacement
Neye ihtiyacın var
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: adım 1, 1 resimden 1.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 2, 3 resimden 1. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 2, 3 resimden 2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 2, 3 resimden 3.
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 3, 3 resimden 1. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 3, 3 resimden 2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 3, 3 resimden 3.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 4, 1 resimden 1.
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 5, 1 resimden 1.
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 6, 1 resimden 1.
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 7, 2 resimden 1. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 7, 2 resimden 2.
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 8, 2 resimden 1. Kurio Touch 4S Front & Rear Facing Cameras Replacement: adım 8, 2 resimden 2.
    • Remove the copper wires by using the Tweezers to replace your new camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Khalid AlTamimi
275 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 247
