Ana içeriğe geç
Kurio Touch 4S Power Button Replacement
Neye ihtiyacın var
  1. Kurio Touch 4S Power Button Replacement, Power Button: adım 1, 1 resimden 1.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: adım 2, 3 resimden 1. Kurio Touch 4S Power Button Replacement: adım 2, 3 resimden 2. Kurio Touch 4S Power Button Replacement: adım 2, 3 resimden 3.
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: adım 3, 2 resimden 1. Kurio Touch 4S Power Button Replacement: adım 3, 2 resimden 2.
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: adım 4, 1 resimden 1.
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: adım 5, 1 resimden 1.
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: adım 6, 1 resimden 1.
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: adım 7, 1 resimden 1.
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: adım 8, 1 resimden 1.
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: adım 9, 1 resimden 1.
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: adım 10, 2 resimden 1. Kurio Touch 4S Power Button Replacement: adım 10, 2 resimden 2.
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: adım 12, 1 resimden 1.
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Moin Khan
234 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 469
