Ana içeriğe geç
Kurio Xtreme Back Panel Replacement
Neye ihtiyacın var
  1. Kurio Xtreme Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Back Panel Replacement: adım 2, 2 resimden 1. Kurio Xtreme Back Panel Replacement: adım 2, 2 resimden 2.
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Back Panel Replacement: adım 3, 3 resimden 1. Kurio Xtreme Back Panel Replacement: adım 3, 3 resimden 2. Kurio Xtreme Back Panel Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mallory Myers
1.190 İtibar
7 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G10
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 467
