Giriş
If the power and/or volume buttons on your Kurio Xtreme are no longer working, follow this guide to replace them. Before you begin, make sure that you have a soldering iron and know how to use it.
Neye ihtiyacın var
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
Bir başkası bu kılavuzu tamamladı.
