Ana içeriğe geç
Kyocera DuraForce Pro Battery Replacement
Neye ihtiyacın var
  1. Kyocera DuraForce Pro Battery Replacement, Battery: adım 1, 3 resimden 1. Kyocera DuraForce Pro Battery Replacement, Battery: adım 1, 3 resimden 2. Kyocera DuraForce Pro Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure the device is turned off.
    • Flip the phone onto its backside.
    • Remove the back cover by using a plastic opening tool.
  2. Kyocera DuraForce Pro Battery Replacement: adım 2, 3 resimden 1. Kyocera DuraForce Pro Battery Replacement: adım 2, 3 resimden 2. Kyocera DuraForce Pro Battery Replacement: adım 2, 3 resimden 3.
    • Remove the eight screws with a JIS #0 screwdriver.
  3. Kyocera DuraForce Pro Battery Replacement: adım 3, 3 resimden 1. Kyocera DuraForce Pro Battery Replacement: adım 3, 3 resimden 2. Kyocera DuraForce Pro Battery Replacement: adım 3, 3 resimden 3.
    • Once the back cover is removed, the (6) buttons along the side are going to fall out of place.
  4. Kyocera DuraForce Pro Battery Replacement: adım 4, 3 resimden 1. Kyocera DuraForce Pro Battery Replacement: adım 4, 3 resimden 2. Kyocera DuraForce Pro Battery Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tool from earlier, lift the battery out by wedging it along the edge.
    • Using tweezers, unlock the ribbon cable port and lightly pull the cable upwards until it becomes unplugged.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Dylan Ulbricht
735 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 4,388
