Ana içeriğe geç
Kyocera DuraForce Pro Headphone Jack Replacement
Neye ihtiyacın var
  1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 2. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 3.
    • Flip the phone on its side so that the volume button is facing up.
    • Use the plastic opening tool to remove outer case of the phone.
    • Remove the 8 screws around the outer portion of the phone with a JIS #0 screwdriver.
  2. Kyocera DuraForce Pro Headphone Jack Replacement: adım 2, 3 resimden 1. Kyocera DuraForce Pro Headphone Jack Replacement: adım 2, 3 resimden 2. Kyocera DuraForce Pro Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Remove the 2 screws with the same screwdriver bit.
    • Remove battery from the phone with plastic opening tool.
  3. Kyocera DuraForce Pro Headphone Jack Replacement: adım 3, 3 resimden 1. Kyocera DuraForce Pro Headphone Jack Replacement: adım 3, 3 resimden 2. Kyocera DuraForce Pro Headphone Jack Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Once the battery pops out, use tweezers to gently pull the ribbon out along with it.
    • Remove the 2 screws along the sides of the mounting bracket, then remove the bracket.
  4. Kyocera DuraForce Pro Headphone Jack Replacement: adım 4, 3 resimden 1. Kyocera DuraForce Pro Headphone Jack Replacement: adım 4, 3 resimden 2. Kyocera DuraForce Pro Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Remove final ribbon cable, lift the latch up, and then slide it down. The audio jack will then slide out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Ulbricht
735 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,338
