Ana içeriğe geç
Kyocera Echo Camera Replacement
Neye ihtiyacın var
  1. Kyocera Echo Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Camera Replacement: adım 2, 1 resimden 1.
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Camera Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Camera Replacement, Camera: adım 4, 1 resimden 1.
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Camera Replacement: adım 5, 1 resimden 1.
    • Unscrew two 4.8mm Y000 screws.
  6. Kyocera Echo Camera Replacement: adım 6, 2 resimden 1. Kyocera Echo Camera Replacement: adım 6, 2 resimden 2.
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Camera Replacement: adım 7, 2 resimden 1. Kyocera Echo Camera Replacement: adım 7, 2 resimden 2.
    • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
    • Be careful to not break the circuit board as it is connected to the hinge.
  8. Kyocera Echo Camera Replacement: adım 8, 1 resimden 1.
    • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
  9. Kyocera Echo Camera Replacement: adım 9, 1 resimden 1.
    • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
Sonuç
Alex Kinstedt
483 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Baechle Fall 2018 IUPUI, Team S2-G6, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 236
