Ana içeriğe geç
Kyocera Event Battery Replacement
Neye ihtiyacın var
  1. Kyocera Event Battery Replacement, Battery: adım 1, 3 resimden 1. Kyocera Event Battery Replacement, Battery: adım 1, 3 resimden 2. Kyocera Event Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: adım 2, 1 resimden 1.
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jen Michaels
22 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Michaels Fall 2013 Ohio State, Team 1-1, Michaels Fall 2013 üyesi
OSU-MICHAELS-F13S1G1
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,137
