Ana içeriğe geç
Giriş
This guide will show you how to disassemble the Kyocera Hydro Life phone in order to replace the power button.
  1. Remove the back cover.
    • Remove the back cover.
    • Pry the cover upward from the gap above the charger port as displayed.
  2. Remove the battery.
    • Remove the battery.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Use a PH00 screwdriver to remove the 6 screws from the mid-frame. Removing the screws too carelessly can result in them being damaged or stripped.
    • Use a PH00 screwdriver to remove the 6 screws from the mid-frame.
    • Removing the screws too carelessly can result in them being damaged or stripped.
  5. Remove the back panel trim.
    • Remove the back panel trim.
    • The back panel trim is fairly thin, be cautious when removing it.
  6. Remove the back panel.
    • Remove the back panel.
    • Pry off the 4 corners first.
  7. Remove the power button with the tweezers. Remove the power button with the tweezers.
    • Remove the power button with the tweezers.
Sonuç
Haley Brown
183 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 60
