Ana içeriğe geç
Giriş
A step-by-step rear camera replacement guide for the Kyocera Hydro Life smartphone.
  1. Remove back cover.
    • Remove back cover.
    • The back cover has a gap to grip when removing the cover.
  2. Remover battery. Lift the battery from the bottom of the phone to remove. Lift the battery from the bottom of the phone to remove.
    • Remover battery.
    • Lift the battery from the bottom of the phone to remove.
  3. Using the eyeglass screw driver, remove the 6 screws. Use PH00 Use PH00
    • Using the eyeglass screw driver, remove the 6 screws.
    • Use PH00
  4. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Remove the white sticker.
    • Remove the white sticker.
  6. Gently pry open the camera ribbon slot. This won't take too much pressure to open.
    • Gently pry open the camera ribbon slot.
    • This won't take too much pressure to open.
  7. Remove camera ribbon.
    • Remove camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  8. Carefully pry to loosen all 4 corners of the motherboard to remove. Remove all ribbons in order to remove the motherboard.
    • Carefully pry to loosen all 4 corners of the motherboard to remove.
    • Remove all ribbons in order to remove the motherboard.
  9. Remove the black sticker.
    • Remove the black sticker.
    • Be careful removing, because you will need to place the sticker back on once you have replaced the camera.
  10. Remove the camera.
    • Remove the camera.
    • This step requires breaking metal.
    • Only cut along the camera square.
Sonuç
Morgan Marshall
277 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 3
Her zaman: 59
